Upgraded to 3.0.2.0 and blank screen
ictsupport
Post by ictsupport »
Thanks for the updates 3.0.2.0. I've upgraded from 3.0.1.9.
Update process seems to go well.
I'm trying to access the following Menu item and they've all return a blank page. Only the page the have any results is Audit Log.
Search and Reports >
Message Listing
Message Operations
Total Messages by Date
Top Mail Relays
Top Viruses
Virus Report
Top Senders by Quantity
Top Senders by Volume
Top Recipients by Quantity
Top Recipients by Volume
Top Sender Domains by Quantity
Top Sender Domains by Volume
Top Recipient Domains by Quantity
Top Recipient Domains by Volume
SpamAssassin Score Distribution
SpamAssassin Rule Hits
Any thoughts how i could resolve this ?
onursener
Re: Upgraded to 3.0.2.0 and blank screen
Post by onursener »
I got this too after upgrading 3.0.2.0 from 3.0.1.9
[Mon Apr 10 08:06:36 2017] [error] [client 192.168.XX.XX] PHP Fatal error: main(): The script tried to execute a method or access a property of an incomplete object. Please ensure that the class definition "Filter" of the object you are trying to operate on was loaded _before_ unserialize() gets called or provide a __autoload() function to load the class definition in /var/www/html/mailscanner/rep_message_listing.php on line 115, referer: https://hostname.com/mailscanner/reports.php
mreinder
Post by mreinder »
I've the same issue.
Issue identified, PR pending with MailWatch. Keep an eye out for 3.0.2.1 to resolve this specific issue for everyone.
ictsupport
shawniverson wrote: 10 Apr 2017 10:10 Issue identified, PR pending with MailWatch. Keep an eye out for 3.0.2.1 to resolve this specific issue for everyone.
:clap: :clap: :clap:
Thank you !!! Looking forward to it
wouterx
Post by wouterx »
Fix confirmed! Thanks!
maxkmv
Post by maxkmv »
Same problem ...You are not alone!
maxkmv
Post by maxkmv »
UPDATE: I have typed all the fixes from Github and now every report works fine, and I can even combine Blacklisted with Date! Hooray!!
:lol: :clap: :dance: :violin:
ictsupport
All fixed from my end after updating to 3.0.2.1 !! Bravo
