Ok,
I have EFA up and running and allready a few domains are using it as a anti spam /virus gateway. However I stumbled on the next problems:
- I have enabled per-user scoring, but I don't want to enter every domain as a user. Is there a way to use defaults for non existent users? I guess if it is possible in a rule from mailscanner it should also be possible from the database.
- I know it was possible, but is there stil a solution to send users an email if message is blocked as spam and for blocked files?
Thanks,
Roger
a few questions
Re: a few questions
Ok,
To answer the first question myself: I had myself as a administrator But the defaults have to be set by an user called "admin". After adding an administrator named admin and setting spam scores for this user, the defaults were working.
