3.0.1.9 Grey Listed - cannot select emails and move to white list
mshanley
Post by mshanley »
Cannot select emails and move to white list get error after hitting submit button
Forbidden
You don't have permission to access /sgwi/connect.php on this server.
MailWatch for MailScanner v1.2.1-dev running on EFA-3.0.1.9
Re: 3.0.1.9 Grey Listed - cannot select emails and move to white list
mod-security issue. If you watch logs /var/log/httpd, you will likely see it triggered. You can make an exception yourself, but it will be resolve in 3.0.2.0 maintenance release.
Should be resolved in 3.0.2.0.
hossmann
Post by hossmann »
i get the same error in version 3.0.23
Maybe you can help?
Go ahead and disable mod-security in EFA-Configure. I've decided to shut it off in 3.0.2.4.
"A band-aid on a previously healed wound."
