The Mailscanner is running fine and does a great job!
How can I add the domains (6000+) to this file: https://wiki.efa-project.org/doku.php?i ... il_domains
I'm using Directadmin, can I use a API or something?
Add domains automaticly
Re: Add domains automaticly
If you can get your domains formatted into transport format, simply drop them into /etc/postfix/transport, run postmap /etc/postfix/transport, and reload postfix. A cron job may even be helpful to keep transport file regularly updated for you
OK last question, where can I turn off Greylisting?
Please choose an option:
0) Logout from ssh 8) Mail Settings
1) Shell 9) Spam Settings
2) Reboot system 10) Mysql Recovery
3) Halt system 11) Apache Settings
4) IP Settings 12) Virus Settings
5) Tunables 13) System Restore
6) MailWatch Settings 14) Update Now
7) Auto Update 15) Maintenance Mode
