Update to V. 3.0.1.9 FAILED. Updates cancelled
Posted: 27 Mar 2017 09:50
by global
HI All,
i am not able to update to version 3.0.1.9 due to a sendmail: fatal error!
Update to Version 3.0.1.9 FAILED. Updates cancelled.
thx in advance
Global
Re: Update to V. 3.0.1.9 FAILED. Updates cancelled
Posted: 27 Mar 2017 11:35
Actually, the real error would have been higher up in the scrollback.
Can you see the error?
Posted: 27 Mar 2017 11:45
by global
Version check failed. Got the following error when calling the 'mysql' command line client
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
FATAL ERROR: Upgrade failed
MariaDB Upgrade Failed, rolling back
hmmm, i could not remember that i changed the mysql root password.
Posted: 27 Mar 2017 11:52
Can you successfully log into mysql yourself? (password is in /etc/EFA-Config)
mysql -u root -p
Posted: 27 Mar 2017 12:55
by global
sorry for the delay,
no i can't
Posted: 27 Mar 2017 12:57
Then your mysql password is indeed different...
You will need to perform a mysql password reset
https://help.ubuntu.com/community/MysqlPasswordReset
Set the password to what you have in /etc/EFA-Config
Posted: 27 Mar 2017 13:38
by global
OK thank you very much
