Upgrade 3.0.1.9 - Cannot access web page
Posted: 26 Mar 2017 13:42
After upgrading, when I try to access the mailscanner webpage I get:
The following conf.php mandatory entries are missing, check and compare your conf.php with conf.php.example.
- LDAP_SSL
I then added "defile ('LDAP_SSL' true);" to /var/www/html/mailscanner/conf.php
and now get:
Forbidden
You don't have permission to access /mailscanner/status.php on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
- LDAP_SSL
and now get:
Forbidden
