Kill Large Scale Spammers quickly
Posted: 25 Mar 2017 00:10
A few weeks ago, we started getting extremely large queues of spam, typically between 10k and 100k emails in the queue. Always all spam.
Because of this, proper emails were taking 4-12 hours to get through the filter.
We took some steps with the firewall to avoid this. But I quickly noticed that the ip-base was sporadic, but the domains were always the same. Not the same domains every time, but that one domain was sending all the spam.
Which is great for me. because I already wrote a script that would clean out large amounts of mail that I specify if/when there is a pattern.
Since these 'attacks' won' t go away,
I now have a cron job running this script. And I thought it may help others.
Use it if you'd like. The LIMIT variable is the max number of emails a domain should be sending. Mine is 400 because a client of ours generates 300 or so emails at a time occasionally. And I didn't want his deleted. I recommend you analyze your need first before running this.
#!/bin/bash
# The LIMIT variable is the trigger for if someone is sending too much (spammers)
LIMIT=400
COUNTER="0"
temp=""
#Separate and Sort Mailq by sender domain and clear the screen (it produces some output)
#/tmp/Queueload.txt is the text file with sender domains in it.
mailq | grep -v postmaster@ | grep @ | grep -v " " | sed 's/.*\@//' | grep -v ">: " | sort | uniq -c | sort -nr -o /tmp/Queueload.txt
cat /tmp/Queueload.txt | sed 's/ //g' | sed 's/ /,/g' | sed 's/^,//;w /tmp/Queueload.txt'
clear
#mailq begins to be manipulated again starting with /tmp/mailq.txt
mailq | tail -n +2 > /tmp/mailq.txt
#remove unnecessary lines from /tmp/mailq.txt and save the results in /tmp/mailq2.txt
while read j; do
let COUNTER=COUNTER+1;
if [ "$j" != "" ]; then
if [[ "$j" != *"Kbytes in"* ]]; then
temp="$temp""$j";
fi;
else
echo $temp >> /tmp/mailq2.txt;
temp="";
COUNTER="0";
fi;
done < /tmp/mailq.txt
#remove top lines from /tmp/mailq2.txt and create /tmp/mailq3.txt
cat /tmp/mailq2.txt | tail -n +2 > /tmp/mailq3.txt
#start reading Queueload and find out if any domain has sent a number ($NUM) that is greater than the limit ($LIMIT)
#If so, delete all of the mail from this sender domain ($DOMAIN)
while read f; do
NUM=`echo $f | sed 's/,.*//'`
DOMAIN=`echo $f | sed 's/.*,//'`
if [ "$NUM" -gt "$LIMIT" ]
then
while read k; do
if [[ "$k" == *"$DOMAIN"* ]]; then
echo $k | cut -c1-11 | postsuper -d -;
fi;
done < /tmp/mailq3.txt
fi
done < /tmp/Queueload.txt
#cleanup tmp files
rm /tmp/Queueload.txt
rm /tmp/mailq*.txt
#!/bin/bash
LIMIT=400
COUNTER="0"
temp=""
clear
while read j; do
temp="$temp""$j";
fi;
else
temp="";
COUNTER="0";
fi;
while read f; do
then
while read k; do
fi;
fi
#cleanup tmp files
rm /tmp/mailq*.txt
