all mail just disappears
Posted: 15 Mar 2017 11:19
by Woger
I have a vps build on the vmdk image of the latest version. Everything seems to be working fine. When I send a message using telnet, postfix says "queued for delivery". However after that nothing happens, the mail just disappears. The maillog just mentioned the connection en after a while a timeout on the connection.
I also tried a script installation on a fresh centos system with the exact same problem. Where can I troubleshoot this? It must be something with Postfix, but even putting debug level on 10 doesn't give any more info.
Thanks,
Roger
Re: all mail just disappears
Posted: 15 Mar 2017 19:48
by Woger
I found out that if I stop MailScanner it is automatically restarted and the monitoring mail is in mailwatch and also sent to the postmaster account (externally). Also when I try to send an email, the only evidence I can find is the time changed on the /var/spool/postfix/incoming directory.
Posted: 16 Mar 2017 14:43
by Woger
Well, I don't know where to look any further. I'll dump a log so maybe someone can see what's wrong.
Mar 16 15:17:38 mailgateway2 postfix/smtpd[7942]: watchdog_start: 0x7f47b7441cd0
Mar 16 15:17:38 mailgateway2 postfix/smtpd[7942]: proxymap stream disconnect
Mar 16 15:17:38 mailgateway2 postfix/smtpd[7942]: rewrite stream disconnect
Mar 16 15:17:38 mailgateway2 postfix/smtpd[7942]: watchdog_stop: 0x7f47b7441cd0
Mar 16 15:19:18 mailgateway2 postfix/smtpd[7942]: idle timeout -- exiting
Mar 16 15:20:25 mailgateway2 postfix/postfix-script[9852]: stopping the Postfix mail system
Mar 16 15:20:25 mailgateway2 postfix/master[7819]: terminating on signal 15
Mar 16 15:20:26 mailgateway2 postfix/postfix-script[9928]: starting the Postfix mail system
Mar 16 15:20:26 mailgateway2 postfix/master[9930]: daemon started -- version 3.1.3, configuration /etc/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: compatibility_level = 2
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: 2
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const 2
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: mail_version = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: 3.1.3
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const 3.1.3
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: mail_version = 3.1.3
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: syslog_facility = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: mail
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const mail
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: syslog_facility = mail
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: inet_protocols = ipv4
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: ipv4
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const ipv4
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: multi_instance_directories = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: multi_instance_directories =
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: multi_instance_group = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: multi_instance_group =
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: multi_instance_name = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: multi_instance_name =
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: daemon_table_open_error_is_fatal = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: daemon_table_open_error_is_fatal = no
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: dns_ncache_ttl_fix_enable = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: dns_ncache_ttl_fix_enable = no
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: smtputf8_enable = no
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: no
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const no
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: name_mask: ipv4
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: myhostname = mailgateway2.ne**ort.net
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: mailgateway2.ne**ort.net
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const mailgateway2.ne**ort.net
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: mydomain = ne**ort.net
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: ne**ort.net
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const ne*ort.net
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: mail_name = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: Postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const Postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: mail_name = Postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: syslog_name = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: ${multi_instance_name?{$multi_instance_name}:{postfix}}
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: expand ${multi_instance_name?{$multi_instance_name}:{postfix}} -> postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: syslog_name = postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: mail_owner = postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: setgid_group = postdrop
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: postdrop
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const postdrop
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: mydestination = $myhostname, localhost.$mydomain, localhost
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: $myhostname, localhost.$mydomain, localhost
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: mailgateway2.ne*ort.net
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: expand $myhostname, localhost.$mydomain, localhost -> mailgateway2.ne**ort.net, localhost.ne**ort.net, localhost
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: myorigin = $mydomain
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: $mydomain
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: expand $mydomain -> ne**ort.net
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: relayhost = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: relayhost =
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: daemon_directory = /usr/libexec/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: /usr/libexec/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const /usr/libexec/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: data_directory = /var/lib/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: /var/lib/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const /var/lib/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: command_directory = /usr/sbin
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: /usr/sbin
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const /usr/sbin
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: meta_directory = /etc/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: /etc/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const /etc/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: queue_directory = /var/spool/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: /var/spool/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const /var/spool/postfix
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: shlib_directory = no
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: process_id_directory = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: pid
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const pid
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: process_id_directory = pid
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: inet_interfaces = all
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: all
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const all
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: proxy_interfaces = 185.110.175.75
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: 185.110.175.75
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const 185.110.175.75
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: double_bounce_sender = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: double-bounce
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const double-bounce
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: double_bounce_sender = double-bounce
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: default_privs = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: nobody
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const nobody
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: default_privs = nobody
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: alias_database = hash:/etc/aliases
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: hash:/etc/aliases
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const hash:/etc/aliases
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: mail_release_date = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: 20161001
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const 20161001
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: mail_release_date = 20161001
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: default_database_type = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: default_database_type = hash
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: hash_queue_names = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: deferred, defer
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const deferred, defer
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: hash_queue_names = deferred, defer
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: recipient_delimiter = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: recipient_delimiter =
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: relay_domains = ne**ort.net be**er.nl
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: ne**ort.net be**er.nl
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const ne**ort.net be**er.nl
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: fast_flush_domains = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: $relay_domains
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: expand $relay_domains -> ne**ort.net be**er.nl
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: fast_flush_domains = ne**ort.net be**er.nl
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: export_environment = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: TZ MAIL_CONFIG LANG
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const TZ MAIL_CONFIG LANG
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: export_environment = TZ MAIL_CONFIG LANG
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: import_environment = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: MAIL_CONFIG MAIL_DEBUG MAIL_LOGTAG TZ XAUTHORITY DISPLAY LANG=C
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const MAIL_CONFIG MAIL_DEBUG MAIL_LOGTAG TZ XAUTHORITY DISPLAY LANG=C
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: import_environment = MAIL_CONFIG MAIL_DEBUG MAIL_LOGTAG TZ XAUTHORITY DISPLAY LANG=C
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: mynetworks_style = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: ${{$compatibility_level} < {2} ? {subnet} : {host}}
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: $compatibility_level
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: host
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: expand ${{$compatibility_level} < {2} ? {subnet} : {host}} -> host
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: mynetworks_style = host
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: debug_peer_list = be**er.nl
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: be**er.nl
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const be**er.nl
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: default_verp_delimiters = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: +=
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const +=
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: default_verp_delimiters = +=
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: verp_delimiter_filter = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: -=+
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const -=+
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: verp_delimiter_filter = -=+
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: parent_domain_matches_subdomains = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: debug_peer_list,fast_flush_domains,mynetworks,permit_mx_backup_networks,qmqpd_authorized_clients,relay_domains,smtpd_access_maps
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const debug_peer_list,fast_flush_domains,mynetworks,permit_mx_backup_networks,qmqpd_authorized_clients,relay_domains,smtpd_access_maps
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: parent_domain_matches_subdomains = debug_peer_list,fast_flush_domains,mynetworks,permit_mx_backup_networks,qmqpd_authorized_clients,relay_domains,smtpd_access_maps
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: alternate_config_directories = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: alternate_config_directories =
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: bounce_service_name = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: bounce
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const bounce
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: bounce_service_name = bounce
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: cleanup_service_name = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: cleanup
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const cleanup
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: cleanup_service_name = cleanup
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: defer_service_name = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: defer_service_name = defer
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: pickup_service_name = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: pickup
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const pickup
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: pickup_service_name = pickup
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: queue_service_name = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: qmgr
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const qmgr
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: queue_service_name = qmgr
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: rewrite_service_name = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: rewrite
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const rewrite
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: rewrite_service_name = rewrite
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: showq_service_name = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: showq
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const showq
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_update: showq_service_name = showq
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_lookup: error_service_name = (notfound)
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: mac_parse: error
Mar 16 15:20:50 mailgateway2 postfix/smtpd[9947]: dict_eval: const error
Mar 16 15:21:04 mailgateway2 postfix/smtpd[9947]: < 262.static.ziggozakelijk.nl[213.124.*.98]: mail from ?:info@w*r.nl
Mar 16 15:21:04 mailgateway2 postfix/smtpd[9947]: > 262.static.ziggozakelijk.nl[213.124.*.98]: 501 5.5.4 Syntax: MAIL FROM:<address>
Mar 16 15:21:04 mailgateway2 postfix/smtpd[9947]: watchdog_pat: 0x7fc4ba2590e0
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: < 262.static.ziggozakelijk.nl[213.124.*.98]: mail from:info@w*r.nl
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: extract_addr: input: info@w*r.nl
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: smtpd_check_addr: addr=info@w*r.nl
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: connect to subsystem private/rewrite
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: send attr request = rewrite
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: send attr rule = local
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: send attr address = info@w*r.nl
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: private/rewrite socket: wanted attribute: flags
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: input attribute name: flags
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: input attribute value: 0
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: private/rewrite socket: wanted attribute: address
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: input attribute name: address
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: input attribute value: info@w*r.nl
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: private/rewrite socket: wanted attribute: (list terminator)
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: input attribute name: (end)
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: rewrite_clnt: local: info@w*r.nl -> info@w*r.nl
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: send attr request = resolve
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: send attr sender =
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: private/rewrite socket: wanted attribute: transport
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: input attribute name: transport
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: input attribute value: smtp
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: private/rewrite socket: wanted attribute: nexthop
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: input attribute name: nexthop
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: input attribute value: w*r.nl
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: private/rewrite socket: wanted attribute: recipient
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: input attribute name: recipient
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: input attribute value: 4096
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: resolve_clnt: `' -> `info@w*r.nl' -> transp=`smtp' host=`w*r.nl' rcpt=`info@w*r.nl' flags= class=default
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: ctable_locate: install entry key info@w*r.nl
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: extract_addr: in: info@w*r.nl, result: info@w*r.nl
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: send attr address = double-bounce
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: input attribute value: double-bounce@ne**ort.net
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: rewrite_clnt: local: double-bounce -> double-bounce@ne**ort.net
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: smtpd_check_rewrite: trying: permit_inet_interfaces
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: permit_inet_interfaces: 262.static.ziggozakelijk.nl 213.124.*.98
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: fsspace: .: block size 4096, blocks free 21007588
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: smtpd_check_queue: blocks 4096 avail 21007588 min_free 0 msg_size_limit 10240000
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: > 262.static.ziggozakelijk.nl[213.124.*.98]: 250 2.1.0 Ok
Mar 16 15:21:14 mailgateway2 postfix/smtpd[9947]: watchdog_pat: 0x7fc4ba2590e0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: < 262.static.ziggozakelijk.nl[213.124.*.98]: rcpt to:roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: extract_addr: input: roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: smtpd_check_addr: addr=roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr request = rewrite
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr rule = local
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr address = roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: private/rewrite socket: wanted attribute: flags
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute name: flags
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute value: 0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: private/rewrite socket: wanted attribute: address
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute name: address
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute value: roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: private/rewrite socket: wanted attribute: (list terminator)
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute name: (end)
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: rewrite_clnt: local: roger@be**er.nl -> roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr request = resolve
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr sender =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: private/rewrite socket: wanted attribute: transport
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute name: transport
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute value: smtp
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: private/rewrite socket: wanted attribute: nexthop
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute name: nexthop
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute value: [mail.ne*ort.net]
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: private/rewrite socket: wanted attribute: recipient
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute name: recipient
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute value: 2048
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: resolve_clnt: `' -> `roger@be**er.nl' -> transp=`smtp' host=`[mail.ne*ort.net]' rcpt=`roger@be**er.nl' flags= class=relay
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: ctable_locate: install entry key roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: extract_addr: in: roger@be**er.nl, result: roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: >>> START Client host RESTRICTIONS <<<
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=permit_sasl_authenticated
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=permit_sasl_authenticated status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_rbl_client
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: reject_rbl_addr: Client host 213.124.*.98
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: dns_query: 98.98.124.213.zen.spamhaus.org (A): Host not found
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: ctable_locate: install entry key 98.98.124.213.zen.spamhaus.org
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_rbl_client status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: >>> END Client host RESTRICTIONS <<<
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: >>> START Helo command RESTRICTIONS <<<
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=check_helo_access
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: check_domain_access: w*r.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=check_helo_access status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_invalid_hostname
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: reject_invalid_hostname: w*r.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_invalid_hostname status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: >>> END Helo command RESTRICTIONS <<<
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: >>> START Sender address RESTRICTIONS <<<
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=check_sender_access
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: check_mail_access: info@w*r.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: ctable_locate: move existing entry key info@w*r.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: check_access: info@w*r.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=check_sender_access status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_non_fqdn_sender
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: reject_non_fqdn_address: info@w*r.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_non_fqdn_sender status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_unknown_sender_domain
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: reject_unknown_address: info@w*r.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: ctable_locate: leave existing entry key info@w*r.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: reject_unknown_mailhost: w*r.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: lookup w*r.nl type MX flags 0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: dns_query: w*r.nl (MX): OK
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: dns_query: reply len=113 ancount=3 nscount=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: dns_get_answer: type MX for w*r.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_unknown_sender_domain status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: >>> END Sender address RESTRICTIONS <<<
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: >>> START Recipient address RESTRICTIONS <<<
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=permit_mynetworks
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: permit_mynetworks: 262.static.ziggozakelijk.nl 213.124.*.98
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: match_hostname: mynetworks: 262.static.ziggozakelijk.nl ~? 127.0.0.0/8
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: match_hostaddr: mynetworks: 213.124.*.98 ~? 127.0.0.0/8
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: match_list_match: 262.static.ziggozakelijk.nl: no match
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: match_list_match: 213.124.*.98: no match
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=permit_mynetworks status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=defer_unauth_destination
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: reject_unauth_destination: roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: permit_auth_destination: roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: ctable_locate: move existing entry key roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=defer_unauth_destination status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: >>> END Recipient address RESTRICTIONS <<<
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_unauth_destination
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: ctable_locate: leave existing entry key roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_unauth_destination status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_non_fqdn_recipient
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: reject_non_fqdn_address: roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_non_fqdn_recipient status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_unknown_recipient_domain
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: reject_unknown_address: roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: reject_unknown_mailhost: be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: lookup be**er.nl type MX flags 0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: dns_query: be**er.nl (MX): OK
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: dns_query: reply len=116 ancount=3 nscount=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: dns_get_answer: type MX for be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=reject_unknown_recipient_domain status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=check_recipient_access
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: check_mail_access: roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: check_access: roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: check_domain_access: be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=check_recipient_access status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=check_policy_service
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: trying... [127.0.0.1]
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: auto_clnt_open: connected to 127.0.0.1:2501
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr request = smtpd_access_policy
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr protocol_state = RCPT
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr protocol_name = ESMTP
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr client_address = 213.124.*.98
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr client_name = 262.static.ziggozakelijk.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr client_port = 35297
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr reverse_client_name = 262.static.ziggozakelijk.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr helo_name = w*r.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr sender = info@w*r.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr recipient = roger@be**er.nl
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr recipient_count = 0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr queue_id =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr instance = 26db.58ca9f5a.1357e.0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr size = 0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr etrn_domain =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr stress =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr sasl_method =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr sasl_username =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr sasl_sender =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr ccert_subject =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr ccert_issuer =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr ccert_fingerprint =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr ccert_pubkey_fingerprint =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr encryption_protocol =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr encryption_cipher =
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr encryption_keysize = 0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: send attr policy_context =
Mar 16 15:21:25 mailgateway2 sqlgrey: perf: spent 0s cleaning: from_awl (0) domain_awl (0) connect (0)
Mar 16 15:21:25 mailgateway2 sqlgrey: grey: from awl match: updating 213.124.*.98(213.124.*.98), info@w*r.nl(info@w*r.nl)
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: 127.0.0.1:2501: wanted attribute: action
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute name: action
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute value: PREPEND X-Greylist: from auto-whitelisted by SQLgrey-1.8.0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: 127.0.0.1:2501: wanted attribute: (list terminator)
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: check_table_result: inet:127.0.0.1:2501 PREPEND X-Greylist: from auto-whitelisted by SQLgrey-1.8.0 policy query
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: generic_checks: name=check_policy_service status=0
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: >>> CHECKING RECIPIENT MAPS <<<
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: maps_find: recipient_canonical_maps: roger@be**er.nl: not found
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: match_string: mydestination: be**er.nl ~? mailgateway2.ne**ort.net
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: match_string: mydestination: be**er.nl ~? localhost.ne**ort.net
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: match_list_match: be**er.nl: no match
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: maps_find: recipient_canonical_maps: @be**er.nl: not found
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: mail_addr_find: roger@be**er.nl -> (not found)
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: maps_find: canonical_maps: roger@be**er.nl: not found
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: maps_find: canonical_maps: @be**er.nl: not found
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: maps_find: virtual_alias_maps: roger@be**er.nl: not found
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: maps_find: virtual_alias_maps: @be**er.nl: not found
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: before input_transp_cleanup: cleanup flags = enable_header_body_filter enable_automatic_bcc enable_address_mapping enable_milters
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: after input_transp_cleanup: cleanup flags = enable_header_body_filter enable_automatic_bcc enable_address_mapping
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: name_mask: sendmail
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: name_mask: verify
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: connect to subsystem public/cleanup
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: public/cleanup socket: wanted attribute: queue_id
Mar 16 15:21:25 mailgateway2 postfix/smtpd[9947]: input attribute name: queue_id
Mar 16 15:21:35 mailgateway2 postfix/smtpd[9947]: < 262.static.ziggozakelijk.nl[213.124.*.98]: RSET
Mar 16 15:21:35 mailgateway2 postfix/smtpd[9947]: > 262.static.ziggozakelijk.nl[213.124.*.98]: 250 2.0.0 Ok
Mar 16 15:21:35 mailgateway2 postfix/smtpd[9947]: watchdog_pat: 0x7fc4ba2590e0
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: smtp_get: timeout
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: > 262.static.ziggozakelijk.nl[213.124.*.98]: 421 4.4.2 mailgateway2.ne**ort.net Error: timeout exceeded
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: match_hostname: smtpd_client_event_limit_exceptions: 262.static.ziggozakelijk.nl ~? 127.0.0.0/8
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: match_hostaddr: smtpd_client_event_limit_exceptions: 213.124.*.98 ~? 127.0.0.0/8
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: match_list_match: 262.static.ziggozakelijk.nl: no match
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: match_list_match: 213.124.*.98: no match
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: send attr request = disconnect
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: send attr ident = smtp:213.124.*.98
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: private/anvil: wanted attribute: status
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: input attribute name: status
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: input attribute value: 0
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: private/anvil: wanted attribute: (list terminator)
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: input attribute name: (end)
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: timeout after RSET from 262.static.ziggozakelijk.nl[213.124.*.98]
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: disconnect from 262.static.ziggozakelijk.nl[213.124.*.98] ehlo=1 mail=1/2 rcpt=1 rset=1 commands=4/5
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: master_notify: status 1
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: connection closed
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: watchdog_stop: 0x7fc4ba2590e0
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: watchdog_start: 0x7fc4ba2590e0
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: auto_clnt_close: disconnect private/tlsmgr stream
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: rewrite stream disconnect
Mar 16 15:26:35 mailgateway2 postfix/smtpd[9947]: auto_clnt_close: disconnect 127.0.0.1:2501 stream
Posted: 18 Mar 2017 09:37
by darky83
In the mailwatch webinterface is there a whitelist entry on the black/whitelist page for 127.0.0.1 to default?
Posted: 18 Mar 2017 10:40
by Woger
Yes there is.
Found some more however. If I send from a local server (relayed by network) within 192.168.0 network I get after data:
354 End data with <CR><LF>.<CR><LF>
250 2.0.0. Ok: queued as 98DA060618
And the mail is completely checked and appears in Mailwatch. (however stopped as spam which shouldn't because spamassassin score is lower then allowed).
from outside the firewall/network I get:
354 Please start mail input.
250 Mail queued for delivery
System mails (auto restart messages) are sent normally.
I also disabled Mailscanner. The message is put in hold as it should and when I start Mailscanner it disappears and postfix/incoming changes time. So it looks like it does everything it should however, the mail disappears and there is nothing in the logs.
Posted: 18 Mar 2017 10:55
by darky83
Well from the outside you seem to get a timeout.
Is there a specific firewall in front of the box, for example a Cisco ASA firewall?
If so try to disable smtp inspection and see if that works.
Posted: 18 Mar 2017 11:00
by Woger
Yes,
There is a pfsense in front of the network. The server is 1:1 natted.
I'll check if I can find the setting.
Thanks,
Roger
Edit: No, it seems to be possible with pfsense but it's not enabled.
Posted: 18 Mar 2017 11:17
by darky83
Well you can try to send a unredacted debug to us using:
wget http://dl.efa-project.org/debug/send-debug-report.sh
chmod 700 send-debug-report.sh
sudo ./send-debug-report.sh
But note that most info of your system, config and logs will be send to me.
Posted: 18 Mar 2017 11:21
by Woger
Strange thing is that I only get a connection in the logs, where I get complete Postfix and mailscanner logs from locally send email.
Posted: 18 Mar 2017 11:24
by Woger
I installed it.
If you want direct access to the server let me know.
Greetings,
Roger
Posted: 18 Mar 2017 12:32
by darky83
It somehow seems that the connection from external (in your case from ziggo) gets a timeout after 2 minutes.
I just used telnet to send a message to your server from external and that is accepted..
I just send you a mail reply.
Posted: 18 Mar 2017 14:11
by Woger
Well,
Darky found out it has something to do with the sqlgrey program. After disabling sqlgrey everything started working. Very strange problem, but for now it works.
Thanks very much Darky!
Posted: 18 Mar 2017 21:06
