hi to everyone,
I would need to configure a rule in filename.rules.conf that blocks the excel file if the name is composed only by numbers, for example 12345.xls.
I tried to enter
deny [0-9] \. xls $ - -
deny [0-9] \. .xlsx $ - -
but this block all excel files that contain at least one number.
What would be the correct syntax?
Thank you
filesnames that contain only numbers
Re: filesnames that contain only numbers
Try this
^[0-9]+\.xlsx$Re: filesnames that contain only numbers
thank you for your quick relply
it works perfectly!
thank you very much
it works perfectly!
thank you very much
