blocked contents
ckruijntjens
blocked contents
Post by ckruijntjens »
Hello all,
I installed efa and so far working good for me. However i have a issue where all attachements are allowed. I want to block specific extensions and when i look at the rules in
archives.filetype.rules.conf or archives.filename.rules.conf
the extension should be blocked but its not. Des anyone had this problem to? Or do i need to configure something here to make it work?
Chris Kruijntens.
e-d-i-t
Re: blocked contents
Post by e-d-i-t »
What kind of extensions do you wish to exclude?
Because if it is an archive-type you want to exclude, I would think of checking filename.rules.conf or filetype.rules.conf instead of archives.filetype.rules.conf or archives.filename.rules.conf.
Especially filetype.rules.conf, as it looks like it is leading as it allows archives in general.
