Hola,
is the only way of getting 3.0.1.8 is to deploy 3.0.1.5 and update from there?
Grtz,
Ronald
3.0.1.8 fresh deployment
Re: 3.0.1.8 fresh deployment
At the moment. I tell you what, I'll work on this this weekend
I'll check regularly then!
Thanks in advance!
BTW, is there an export tool for SQLBlack/white list? Or should I just use the generic mySQL thingies ...?
Grtz,
Ronald
Thanks in advance!
Grtz,
Ronald
Not currently, but I recall this being on my todo.
