Different receive and send time & delay
Posted: 17 Feb 2017 14:24
by bernikm
We're using the latest E.F.A as relay for all e-mails that are forwarded to our internal Exchange server. It works great, but we have 2 problems:
1. The difference between time that the server receives and sends e-mail is -1 hour. It receives at normal time like 02:00 pm, sends to exchange and marks as it has time 01:00 pm.I have checked all time zone settings that are set correctly to our time, but it looks like that every mail in stamped with time -1 than it should be.
Looking in postfix queue sent time is 2017/02/17 01:53 but on mail header it is 2017/02/17 02:53 that is correct time. So in any way relay stamps mail with time diffenrece -1 hour ??
What can we do to solve this ?
2. We noticed quite a delay for processing e-mails that are in postfix queue (not listed as grey-list waiting) and then delivered further to Exchange. The delay between receiving and sending mail on E.F.A is sometimes more than 15 min.
Looking on server, there is no impact on performance or memory, I set 4vCPU and 8GB RAM to VM, but the processing is the same.
Any ideas how to fix this ?
Thank you in advance
Best regards,
Mike
Re: Different receive and send time & delay
Posted: 17 Feb 2017 23:36
I wonder if changing the timezone may help?
Posted: 20 Feb 2017 07:29
by bernikm
Timezone is set to CET (+1) that is our local time. If I change it to UTC I think that all mails in mailrelay GUI will be shown as -1 at hour time ?
