Export blacklist and whitelist from ESVA and import to EFA
darky83
Site Admin
Post by darky83 »
If you are migrating from ESVA to EFA you can export and import the black/whitelist with a simple script.
note: This script doesn’t check for double entry’s.
ssh to your ESVA server
wget http://dl.efa-project.org/exportlists.sh
chmod +x exportlists.sh
./exportlists.sh
There should be a output.sql file in the directory where you executed the script. Copy this to your EFA server. You can use scp for example: s
cp output.sql efaadmin@<yourEFAhost>:
Now ssh to your EFA machine.
Execute the following command to import the black/whitelist:
mysql -u root -p`cat /etc/mysql/EFA.cnf` < output.sql
All done.
*Optional*
By default, the black and whitelist entry’s are added under the root (id=1) account of EFA. If you want them added under another account, just change the @userid variable in the first line of output.sql. To find out the userid:
  • Login to the EFA webinterface
  • Go to settings -> accounts
  • Click on the icon of the desired user
  • The id can be found in the addressbar, for example http://<EFAhost>/accounts/user/2/. 2 is the userid.
Source: http://www.tuser.nl
