GEOIP download problem sice update to 3.0.1.8
Pukkeltje
Post by Pukkeltje » 09 Feb 2017 13:52
Since the upgrade to 3.0.1.8, I get this error while updating de GEOIP databases:
Downloading file, please wait...
Error occurred while downloading GeoIP IPv4 data file: cURL error 7: Failed to connect to 2400:cb00:2048:1::6810:262f: Network is unreachable
Error occurred while downloading GeoIP IPv6 data file: cURL error 7: Failed to connect to 2400:cb00:2048:1::6810:262f: Network is unreachable
Download complete, unpacking files...
GeoIP IPv4 data file successfully unpacked
GeoIP IPv6 data file successfully unpacked
Process completed!
The files in the directory are 0 bytes:
drwxrwxr-x 2 root apache 4096 Feb 9 14:45 .
drwxr-xr-x 6 root root 4096 Feb 7 23:52 ..
-rw-r--r-- 1 apache apache 0 Feb 9 14:45 GeoIP.dat
-rw-r--r-- 1 apache apache 0 Feb 9 14:45 GeoIPv6.dat
-rw-r--r-- 1 root root 70 Jan 10 16:51 .gitignore
It looks like IP resolving is only to IPv6 address. I only have a IPv4 network connection.
Re: GEOIP download problem sice update to 3.0.1.8
Post by shawniverson » 11 Feb 2017 14:29
Odd. I am able to resolve to ipv4 addresses on 3.0.1.8.
What are getting when you resolve the following?
dig dev.maxmind.com
kettchenkuno
Post by kettchenkuno » 22 Mar 2017 09:12
Same here... :think:
[admin@SMX2 ~]$ [b]dig dev.maxmind.com[/b]
; <<>> DiG 9.8.2rc1-RedHat-9.8.2-0.47.rc1.el6_8.4 <<>> dev.maxmind.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 54235
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;dev.maxmind.com.               IN      A
;; ANSWER SECTION:
dev.maxmind.com.        1152    IN      CNAME   maxminddev.wpengine.com.
maxminddev.wpengine.com. 119    IN      A       104.197.225.108
;; Query time: 71 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Wed Mar 22 10:04:46 2017
;; MSG SIZE  rcvd: 83
[admin@SMX2 ~]$ [b]dig geolite.maxmind.com[/b]
; <<>> DiG 9.8.2rc1-RedHat-9.8.2-0.47.rc1.el6_8.4 <<>> geolite.maxmind.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 24794
;; flags: qr rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 0, ADDITIONAL: 0
;geolite.maxmind.com.           IN      A
;; ANSWER SECTION:
geolite.maxmind.com.    15      IN      CNAME   geolite.maxmind.com.cdn.cloudflare.net.
geolite.maxmind.com.cdn.cloudflare.net. 299 IN A 104.16.38.47
geolite.maxmind.com.cdn.cloudflare.net. 299 IN A 104.16.37.47
;; Query time: 73 msec
;; WHEN: Wed Mar 22 10:05:49 2017
;; MSG SIZE  rcvd: 121
Already tried to add the ip's to host file but this results in
Error occurred while downloading GeoIP IPv4 data file: cURL error 7: couldn't connect to host
Error occurred while downloading GeoIP IPv6 data file: cURL error 7: couldn't connect to host
Process completed!
Tried to manually download the file via curl with
curl -O http://geolite.maxmind.com/download/geo ... oIP.dat.gz
That works. :think: :think:
w_bufffet
Post by w_bufffet » 22 Jan 2019 16:00
And now they discontinued their free service.
on their website:
GeoLite Legacy databases were discontinued on January 2, 2019. Learn more
any ideas on what should be done, except deleting the GeoIP files?
Post by henk » 22 Jan 2019 16:24
ideas? At least one: Search this forum :oops:
How? : viewtopic.php?f=5&t=2974
Result: viewtopic.php?f=13&t=3311
