While looking to building a email gateway to front my exchange I found first, Mailscanner then EFA. Very easy to build and setup. I am still playing with it and there seems to a lot that been built in over the years.
What is enabled by default, and what do you need to be tweaked for an effective filtering solution?
Hello EFA
Re: Hello EFA
Tweaking is welcome. Check out the wiki and the forums for various tips.
A great place to see the default configurations is the various configs, such as
/etc/postfix/main.cf
/etc/mail/spamassassin/*
Also, check the various options in EFA-Configure, which will handle many common settings for you.
