We would also like to thank everyone for their support and contributions to this project.
The following issues have been fixed (hopefully) in 3.0.1.7:
Issue #346 Bug - EFA 3.0.1.6 mailwatch is empty after Update GeoIP Database
Updated MailWatch to 1.2.0 - RC4 latest development
3) If the update fails for any reason, collect relevant logs or screen
outputs/screenshots and revert to your snapshot
Launch EFA-Configure from console or secure shell
(sudo /usr/local/sbin/EFA-Configure)
Choose option 14) Update Now
continue the update process to 3.0.1.7.
if present.
After updating, please run "Update GeoIP Database" update as soon as
possible from MailWatch under Tools/Links.
