DKIM verifying doesen´t work anymore.
I have done one reinstall and then it started to work but after a few days i stopt working again.
The only message I can find is: T_DKIM_INVALID DKIM-Signature header exists but is not valid
There is no referenses that the message has a DKIM key other than this.
Is there anyone that have the same problem.
I am running 3.0.1.5
/Largo
DKIM verifying stop working
Re: DKIM verifying stop working
Do the DKIM signatures test ok manually?
Can you resolve the DKIM records from the EFA?
How do I test that?
If I do a nslookup on gmail I got the folowing result.
[root@efa lasse]# nslookup -type=txt 20161025._domainkey.gmail.com
Server: 127.0.0.1
Address: 127.0.0.1#53
Non-authoritative answer:
20161025._domainkey.gmail.com text = "k=rsa\; p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAviPGBk4ZB64UfSqWyAicdR7lodhytae+EYRQVtKDhM+1mXjEqRtP/pDT3sBhazkmA48n2k5NJUyMEoO8nc2r6sUA+/Dom5jRBZp6qDKJOwjJ5R/OpHamlRG+YRJQqR" "tqEgSiJWG7h7efGYWmh4URhFM9k9+rmG/CwCgwx7Et+c8OMlngaLl04/bPmfpjdEyLWyNimk761CX6KymzYiRDNz1MOJOJ7OzFaS4PFbVLn0m5mf0HVNtBpPwWuCNvaFVflUYxEyblbB6h/oWOPGbzoSgtRA47SHV53SwZjIsVpbq4LxUW9IxAEwYzGcSgZ4n5Q8X8TndowsDUzoccPFGhdwIDAQAB"
Authoritative answers can be found from:
But how do I test DKIM verifying manually?
/Largo
Server: 127.0.0.1
/Largo
I finaly got it working again.
The problem was that I had put in a score for DKIM in spamassassin.conf and that made it stop working.
/Largo
/Largo
