Hello last week we updated our server from version 3.0.0.9 to 3.0.1.5 after a kernel update.
Since the update we can not login tot spamfilter portal. We get a time out..
This is the link we always used, perhaps something had changed? This has worked for years....
https://server.XXXXX.XX/mailscanner/status.php
Is there anybody who knows what is goiing on? Is it in one of the updates perhaps?
Broken Mailwatch
Re: Broken Mailwatch
Do you see anything interesting in the apache logs?
After a lot of spitting and testing i found out that the webpage of mailscanner changed from port 80 to port 443. So i opened that port on the firewall and that did the trick.
It is strange that in none of the updates this was mentioned in the changelogs?! Was this iomplemented in version 3.0.1.0? For years we worked at port 80 and suddenly it changed.
But i'm glad that it is working again!
