I'm a newbie with E.F.A Project and I'm trying to configure one new instance. My setup is pretty simple. I have one server with E.F.A project installed and one Exchange server. Sometimes when my exchange users send e-mails to external recipients their mails are marked as SPAM or with Bad Content and are blocked. What I want to do is to make my E.F.A server send notification to that internal users (e-mail addresses) immediately when their messages are blocked by the E.F.A server. Is it possible?
BR
Internal users SPAM notification
Re: Internal users SPAM notification
You send a message fron Exchange to EFA and EFA send it to external users i suppose ....
If efa deliuver the message to external server there is no way to know if the external server compute the received message and mark it as spam...
The best thing that you can do is to test your mail deliverability here
https://www.mail-tester.com/
if you take 10 points if someone consider spam your messages it is not a your problem
If you have Exchange consider to use my software plugin, write me at nicola.piazzi@gruppocomet.it
Thx
Nicola
Thx
Nicola
