XML-RPC Error: Didn't receive 200 OK from remote server. (HTTP/1.1 404 Not Found) ?
ovizii
Post by ovizii »
If I go to EFA => open a message, scroll to the bottom I see:
not sure what triggered this, might have been me changing names/domains/etc. how do I make sure my hostname and domain in EFA and my /etc/hosts and /etc/sysconfig/network settings are correct?
Found 2 related older threads, could someone clarify how I rectify this issue?
viewtopic.php?f=13&t=1091
viewtopic.php?f=14&t=497
This problem is closely related to my other thread: viewtopic.php?f=14&t=2066
Re: XML-RPC Error: Didn't receive 200 OK from remote server. (HTTP/1.1 404 Not Found) ?
Are you running multiple EFA's with XML-RPC enabled?
ovizii
Post by ovizii »
no I don't but I think this has been solved as I am on the same network although a different subnet with another company who also uses EFA. It seems some routing went wrong and the two EFAs "encountered each other" on the same network.
