EFA and DKIM checks at receiving end
ovizii
Post by ovizii »
So my EFA receives emails and forwards them to my server using opendkim to send and check received emails.
EFA is configured properly (in the config files there is an option to properly add headers at the top of messages and not replace them) and yet my receiving server throws warnings like these:
this one is about an email coming from Google Apps, with proper SPF/DKIM/dmarc setup:
Authentication-Results: mike.knightsenglish.com; dkim=fail
reason="verification failed; unprotected key"
header.d=pacura.ru header.i=@pacura.ru
header.b=J2TxdPbe; dkim-adsp=none (unprotected policy); dkim-atps=neutral
this one is about an email coming from a server under my control, with proper SPF/DKIM/dmarc setup:
Authentication-Results: mike.knightsenglish.com; dkim=pass
reason="4096-bit key; unprotected key"
header.d=intramed.sa.com header.i=@intramed.sa.com
header.b=qL9xD/z+; dkim-adsp=pass; dkim-atps=neutral
Has anyone got an idea how to fix this?
I'd also be happy to skip DKIM checks on incoming messages since they get filtered through EFA anyway and there are DKIM checks already in place.
Anyone familiar with opendkim?
The dmarc policies are:
v=DMARC1; p=reject; pct=100;
v=DMARC1; p=quarantine; pct=25;
so basically the first one says: if it fails, reject 100% of failed emails while the second one says to quarantine 25% of failed emails.
But none of these 2 should fail. I'm sure its because of being EFA in the middle.
###edit###
to make things easier, here is the full email content with all headers of the first email of the two mentioned above: http://pastebin.com/aExuVJG0
ovizii
Re: EFA and DKIM checks at receiving end
Post by ovizii »
figured out how to use opendkim for signing outgoing emails only:
in /etc/opendkim.conf
set
Mode sv
to
Mode s
s=signing
v=verifying
but still, I'd be interested to know how exactly one has to configure EFA so this works properly.
