Mark message with bad content as spam
Posted: 29 Nov 2016 09:33
by ikalmar
I'd like to mark messages with bad contents as spam, but in the mailwatch in theese messages I dont find the action section, to mark message as spam.
Re: Mark message with bad content as spam
Posted: 29 Nov 2016 18:57
by darky83
open the message you want to mark as spam, scroll all the way down.
Under 'SA-Learn' check the checkbox and select 'As Spam' -> submit.
https://wiki.efa-project.org/doku.php?i ... es_as_spam
Posted: 30 Nov 2016 09:26
by ikalmar
Dear Darky. There is NO such section, you wrote, only on normal messages where I can do that. I wrote this topic becouse, there is NO action section, with 'SA-Learn' checkbox in messages with bad content!
Posted: 30 Nov 2016 19:20
by darky83
Ah, messages with bad content (blocked files) are not saved on the system, so there is no way of learning as the message has nog been saved.
Posted: 06 Dec 2016 06:55
by ikalmar
This is a very-very Big Mistake!!! Only the content filtering not always detect bad content of similar letters, so, it should be better, to be stored that mails to teach the Spamassasin, or should be an option, to learn automaticly letters with bad content. For higher rate of spam detection need the teachable spam filter and the content filter works together.
Posted: 10 Dec 2016 10:37
by darky83
if an message with bad content is blocked, it will be blocked the next time also, so there is no need for learning as it will be blocked anyway by the virusscanner.
