Hi, I have found this project fail2web is a fail2ban GUI that communicates with a fail2ban instance via fail2rest
fail2ban allows you to administer the following
Failregex - Delete and add new failregexes
Banned IPs - Ban and Unban IP address
Per Jail Config - Configure find time, max retry and usedns per jail, and view the filelist per jail
Alerting - Notifications when an IP address is banned and unbanned with a user configurable time span
Regex Testing - Testing ignore+fail regexes on your current logs to quickly build and debug regexes
Reporting - Expose the time that an IP address was banned, and show trends via visualizations
with the following features planned in the future
More Jail Controls - Create new jails and expose more settings for current jails
Do you think it is possible to add this feature onto EFA?
Link : https://github.com/Sean-Der/fail2web
fail2web webui
