white- or blacklist entry not working in german language
Posted: 10 Nov 2016 15:25
by 6714
hello,
i can not add a white- or blacklist entry, not from admin, not from normal (ldap) user.
2016-11-10 16_23_39-MailWatch for Mailscanner - Whitelist_Blacklist.png (16.83 KiB) Viewed 6985 times
thanks for info
Re: white- or blacklist entry not working
Posted: 10 Nov 2016 15:47
by 6714
when edit/add content.scanning.rules i become error when save changes
Backing up current file...**ERROR** Could not make backup!
Done with Write_File.
Scheduling reload of MailScanner...Ok.
Your changes will take effect in the next 5 minutes, when MailScanner reloads.
Permissions correct ?
root@mgw /etc/MailScanner > ls -la
total 720
drwxr-xr-x.  5 root root   4096 Nov 10 16:14 .
drwxr-xr-x. 92 root root   4096 Nov 10 15:33 ..
-rw-r--r--   1 root root   7337 Aug 14 18:05 archives.filename.rules.conf
-rw-r--r--   1 root root   1398 Aug 14 18:05 archives.filetype.rules.conf
drwxr-xr-x.  2 root root   4096 Nov  1 21:03 conf.d
-rw-r--r--   1 root root  44134 Aug 14 18:05 country.domains.conf
lrwxrwxrwx   1 root root     34 Nov  1 21:04 custom -> /usr/share/MailScanner/perl/custom
-rw-r--r--   1 root root   4537 Nov  1 21:04 defaults
-rw-r--r--   1 root root    117 Nov  1 21:04 filename.rules
-rw-r--r--   1 root root     13 Nov  1 21:04 filename.rules.allowall.conf
-rw-r--r--   1 root root   8086 Aug 14 18:05 filename.rules.conf
-rw-r--r--   1 root root    117 Nov  1 21:04 filetype.rules
-rw-r--r--   1 root root     13 Nov  1 21:04 filetype.rules.allowall.conf
-rw-r--r--   1 root root   1589 Aug 14 18:05 filetype.rules.conf
-rw-r--r--   1 root root 145940 Nov 10 16:14 MailScanner.conf
drwxr-xr-x.  2 root root   4096 Nov  1 21:04 mcp
-rw-r--r--   1 root root 416488 Nov  9 00:00 phishing.bad.sites.conf
-rw-r--r--   1 root root  19571 Nov  8 06:11 phishing.safe.sites.conf
lrwxrwxrwx   1 root root     30 Nov  1 21:04 reports -> /usr/share/MailScanner/reports
drwxr-xr-x.  2 root root   4096 Nov  1 21:04 rules
-rw-r--r--   1 root root  11805 Nov  3 19:33 spamassassin.conf
-rw-r--r--   1 root root  11592 Nov  1 20:32 spamassassin.conf.rpmnew
lrwxrwxrwx   1 root root     34 Nov  1 21:04 spam.assassin.prefs.conf -> /etc/MailScanner/spamassassin.conf
-rw-r--r--   1 root root   1129 Aug 14 18:05 spam.lists.conf
-rw-r--r--   1 root root   1495 Aug 14 18:05 virus.scanners.conf
-rw-r--r--.  1 root root   2983 Nov  1 00:05 virus.scanners.conf.rpmsave
Posted: 10 Nov 2016 17:24
by 6714
ok when i switch back to language "en" in
then the lists function.
the problem not saving MailScanner Rulesets over Webgui is the same.
Re: white- or blacklist entry not working in german language
Posted: 13 Nov 2016 12:26
Posted: 13 Nov 2016 14:16
by 6714
thanks
