Hola,
I need to change my recursion settings back from DISABLED to ENABLED. I tried that through EFA-Configure, but this didn;t work. Any ideas where to change it manually? Must be in the unbound.conf, but I can't figure out what to change. In the examples in the config file recursion is per zone look like.
Grtz,
Ronald
						change recursion settings
Re: change recursion settings
To enable manually:
/etc/unbound/conf.d/forwarders.conf
forward-zone:
  forward-first: yes
Kinda late, but thanks
