This EFA instance runs as a KVM and the hypervisor is ProxMox.
Oct 30 13:06:59 jacob kernel: Linux version 2.6.32-642.6.2.el6.x86_64 (mockbuild@worker1.b
sys.centos.org) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-17) (GCC) ) #1 SMP Wed Oct 26 0
6:52:09 UTC 2016
Oct 30 13:06:59 jacob kernel: Initializing cgroup subsys cpu
Oct 30 13:06:59 jacob kernel: Initializing cgroup subsys cpuset
Oct 30 13:06:59 jacob rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="1463
" x-info="http://www.rsyslog.com"] start
Oct 30 13:06:59 jacob kernel: imklog 5.8.10, log source = /proc/kmsg started.
Oct 30 06:45:11 jacob savd: update.check: Successfully updated Sophos Anti-Virus from sdds
:SOPHOS
Oct 30 06:42:20 jacob clamd[1832]: SelfCheck: Database status OK.
Oct 30 06:32:20 jacob clamd[1832]: SelfCheck: Database status OK.
Oct 30 06:22:19 jacob clamd[1832]: SelfCheck: Database status OK.
Oct 30 06:12:19 jacob clamd[1832]: SelfCheck: Database status OK.
Oct 30 06:02:19 jacob clamd[1832]: SelfCheck: Database status OK.
Oct 30 05:52:19 jacob clamd[1832]: Database correctly reloaded (8035820 signatures)
Oct 30 05:52:00 jacob clamd[1832]: Reading databases from /var/lib/clamav
Oct 30 05:47:52 jacob clamd[1832]: SelfCheck: Database status OK.
Oct 30 05:45:11 jacob savd: update.check: Successfully updated Sophos Anti-Virus from sdds
:SOPHOS
