Hi Guys,
I need some help here.
I am noticing that spam as well as non-spam emails are getting stuck in the quarantine. Additionally, it seems like users are being notified with {Spam not delivered} for spam that was not delivered to them.
What i would like to happen:
1. non-spam emails to be delivered
2. spam emails with a SA score of <2 should be delivered to user.
3. Spam emails with an SA score of >2 should be stored in quarantine.
My mailscanner config looks like this:
Spam Actions = store custom(spam)
thank you for your assistance.
						HELP non-spam and spam emails are being quarantined
Re: HELP non-spam and spam emails are being quarantined
Check out EFA-Configure
  (/usr/local/sbin/EFA-Configure)
You can modify your EFA install to suit you needs. Check out specifically the spam settings and non-spam settings sections
Hi Thank you for the response.
I changed the following settings:
Non Spam Actions = deliver header "X-Spam-Status:No" custom(nonspam)
and that worked for me.
thank you once again.
