upgrading 3.0.1.3 ->3.0.1.5 GeoIP
Posted: 21 Sep 2016 10:22
Hi Guys,
You did a really great job with this upgrade. Works like a charm. After upgrading the only thing I did was to manually load the GeoIP db.
Happy and thankful guy over here :dance:
By the way: don't mind the errors on boot regarding the yar(a) files, the are loaded anyway. it's a known, harmless issue.
[root@sansspam MailScanner]# clamscan --debug 2>&1 /dev/null | grep "yar loaded"
LibClamAV debug: /var/lib/clamav/EMAIL_Cryptowall.yar loaded
LibClamAV debug: /var/lib/clamav/EK_BleedingLife.yar loaded
LibClamAV debug: /var/lib/clamav/EK_Phoenix.yar loaded
LibClamAV debug: /var/lib/clamav/EK_Eleonore.yar loaded
LibClamAV debug: /var/lib/clamav/EK_Blackhole.yar loaded
LibClamAV debug: /var/lib/clamav/EK_Crimepack.yar loaded
LibClamAV debug: /var/lib/clamav/EK_Angler.yar loaded
LibClamAV debug: /var/lib/clamav/antidebug_antivm.yar loaded
LibClamAV debug: /var/lib/clamav/EK_Zerox88.yar loaded
LibClamAV debug: /var/lib/clamav/EK_Sakura.yar loaded
LibClamAV debug: /var/lib/clamav/EK_Fragus.yar loaded
LibClamAV debug: /var/lib/clamav/EK_Zeus.yar loaded
LibClamAV debug: /var/lib/clamav/EK_ZeroAcces.yar loaded
