Queue display error in latest version
Post by nicola.piazzi »
I tell Inbound a number and outbound the same with a minus
if i click i get permission denied
Re: Queue display error in latest version
/var/spool/mqueue ?
That should even be used. :?:
I will go in there and see what is lingering in there...
It seems to be a permission problem :-( Mailscanner runs with postfix user as other efa installation that works
SOLVED
To install OPENDKIM also SENDMAIL is installed
THen i stopped sendmail service
But noq the command mailq that is used by mailwatch refers to sendmail queue and not postfix one
To solve i substituted mailq command with postqueue -p in postfix.inc.php (two occorrences)
vi /var/www/html/mailscanner/postfix.inc.php
## $last_line = exec('mailq', $output);
$last_line = exec('postqueue -p', $output);
