Hello!
Is there a way to define the quarantine report language per user?
Thx in advance!
HOw to define quarantine report language per user
Re: HOw to define quarantine report language per user
oups look like it's not possible. The quarantine report script does not support multi-languages
here is someone also reporting similar findings, not sure if anything has changed meanwhile. http://lists.mailscanner.info/pipermail ... 01898.html
