now  with Version EFA-3.0.1.3 there is no more the wrapper called f-prot-6
/etc/MailScanner/virus.scanners.conf contains very few wrappers, also wrapers dir is changed
how we can do ? i put old wrapper manually ?
						f-prot-6 removed from mailscanner wrappers
Re: f-prot-6 removed from mailscanner wrappers
You can certainly give it a shot.  (the old script should be in /var/EFA/backup/3.0.1.2)
If it doesn't work, you will probably need to reach out to MailScanner folks on that one.
@nicola: how did it go? Are you still actively using f-prot?
no, now i use only clam and sophos
