reject_unverified_recipient doent work with Exchange 2016
Posted: 07 Sep 2016 08:32
by nicola.piazzi
I have a problem using reject_unverified_recipient to verify under Exchange 2016 that I don’t have with Exchange 2010
Postfix is used to send and receive mail and is between the internet and the internal Exchange Server
Now, when an internet user send an email to our domain postfix verify it making an rctp to to our exchange using reject_unverified_recipient instruction
This worked well with Exchange 2010 but now with Exchange 2016 doesn’t work.
Exchange 2016 needs the installation of Recipient Filter Agent and obviously I installed it.
Now we have Frontend Transport that answer at port 25 and verify recipient at DATA phase and the Hub Transport that answer at port 2525 and verify recipient at RCPT TO
Here Exchange 2016 at port 25 that verify unknown recipient at DATA phase
telnet 10.1.1.126 25
220 GEMMA.gruppocomet.net Microsoft ESMTP MAIL Service ready
helo me
250 GEMMA.gruppocomet.net Hello [10.2.6.4]
mail from:ext@ext.com
250 2.1.0 Sender OK
rcpt to:doesntexist@gruppocomet.it
250 2.1.5 Recipient OK
data
354 Start mail input; end with <CRLF>.<CRLF>
some data
550 5.1.10 RESOLVER.ADR.RecipientNotFound; Recipient not found by SMTP address lookup
Here Exchange 2016 at port 2525 that verify unknown recipient at RCPT TO phase
telnet 10.1.1.126 2525
helo me
250 2.1.0 Sender OK
When I connect to a Postfix configured with reject_unverified_recipient it doesn’t work
I tried to transport domain to Exchange at port 2525 and at port 25 using the parameter smtp_address_verify_target = data
Postfix answer OK at RCPT TO of doesntexist@gruppocomet.it and need some time to answer, so I suppose that it make the call to Exchange
RCPT TO is immediate if I remove reject_unverified_recipient
Someone can help me in this ?
Re: reject_unverified_recipient doent work with Exchange 2016
Posted: 07 Sep 2016 22:52
I don't know if anyone has done this before and succeeded, that I know of anyway...
http://www.gossamer-threads.com/lists/s ... ers/200747
You may want to change gears and build a recipient_access list instead to kill them at the MTA...
viewtopic.php?t=795
