Rollback after EFA 3.0.1.3 Update
Posted: 05 Sep 2016 16:02
by nicola.piazzi
When i do EFA 3.0.1.2 Update server restarted with big problems
CLAM have permission problem
Sophos have other problems
Each message was red, that says that tried to stop mailscanner process
EFA 3.0.1.3 Update not solved
i rolled back, next time i make a new box, sigh
Re: Rollback after EFA 3.0.1.3 Update
Posted: 05 Sep 2016 17:16
Did you happen to capture the update logs from /var/log/EFA?
I would like to examine them and see what went wrong.
Posted: 05 Sep 2016 17:19
Chances are that since you are running Sophos, you simply needed to add the sophos user to the mtagroup, just fyi for anyone running additional virus scanners out there.
I posted a notice regarding this here:
viewtopic.php?f=13&p=6953
Posted: 06 Sep 2016 06:39
by nicola.piazzi
I was in panic and rollback snaphot wihout saving anything
in the future i think to do a dual machine installation, one active and one with new version to try and work with nameservers
