shortircuit malfuncitioning
Posted: 30 Aug 2016 12:32
by nicola.piazzi
I activated shortcircuit for BAYES_ZERO RULE in local.cf with priority
As you can see here if a message get a BAYES_ZERO il get also SHORTCIRCUIT
BUT it executes also other rules, not all but some other yes
[SOLVED] Re: shortircuit malfuncitioning
Posted: 31 Aug 2016 15:46
by nicola.piazzi
RBL Check are asyncronous, so some pass also if there is a shortcircuit
SA core modification is needed to make rbl syncronous
