While running the following command
spamassassin -D --lint 2&>1 | grep failed A quick google search turned up the following link:dbg: diag: [...] module not installed: Net::DNS::Nameserver ('require' failed)
https://bz.apache.org/SpamAssassin/show_bug.cgi?id=7052
short version:
A quick "sudo yum install perl-Net-DNS-Nameserver" and the perl module installed without problem and the error in lint checking went away.With RHEL/CentOS, Net-DNS is split into Net-DNS and Net-DNS-Nameserver.
This causes issues such as:
[snip]
The solution on RHEL/CentOS systems is to install perl-Net-DNS-Nameserver using yum, for example.
My system is a "build from scratch" and others may have this problem.
I'd like to know if it's just me or if it is an actual, real problem. If anyone can check and let me know if they have that module already installed, I'd greatly appreciate it.
