getting error Forbidden. Not a mobile device
bas60
Post by bas60 »
HELP!!
After upgrade to 3.0.1.1
User getting message quarantine report but when they try to view
Ie, Firefox & Chrome
I did a search for this on this forum but nothing found
bas60
Re: getting error Forbidden. Not a mobile device
Post by bas60 »
Found it !!
Port 443 is used by another server ....
Can I change the default port used by EFA to 443 say something like 555 ??
if so How ?
  • edit: /etc/httpd/conf.d/ssl.conf
  • search for: 443
  • change to: 555
  • run the following comand: apachectl configtest
  • look for: "Syntax OK"
  • restart apache: apache2ctl restart
