Are you sure you want to delete userusername?
Posted: 25 Jul 2016 19:42
/var/www/html/mailscanner/languages/en.php:
Needs a space at the end:
Also, if you select Cancel at that point, a webpage displays that simply says "false"
'areusuredel12' => 'Are you sure you want to delete user',Code: Select all
'areusuredel12' => 'Are you sure you want to delete user ',
