Keywords
Posted: 15 Jul 2016 12:27
by bostjanc
Is it possible that specific keywords would be excluded from spam filter?
I know you can put domains in whitelists, but what about keywords? is that possible in EFA?
with best regards
Re: Keywords
Posted: 15 Jul 2016 16:56
Yes :)
Best way is to use spamassassin and create your own rule to give it a negative score. You can use MCP as well, but all it really is another instance of spamassassin.
Re: Keywords
Posted: 15 Jul 2016 17:51
by bostjanc
Hi there.
Thank you for your quick reply.
Any suggesetion how to use spam assasin?
Any quick step-by-step guy how to add keywords?
With best regards
Re: Keywords
Posted: 15 Jul 2016 18:02
Re: Keywords
Posted: 27 Jul 2016 09:49
by bostjanc
Thank you.
