Does EFA use trusted networks setting for SA?
I found this page on the SA wiki, hence my question: https://wiki.apache.org/spamassassin/TrustPath
Re: Does EFA use trusted networks setting for SA?
Answer: no
All locations are "untrusted," including internal networks. This prevents spamming from the inside of the network via EFA.
However, you can explicitly define a trusted network, if desired.
thanks, I was just reading up on internal_networks and trusted_networks as I'm really new to this subject so I thought I'd ask here first.
Still reading up on the subject and trying to figure out its possible use/usage.
