Whitelist is not work when missing "To" filed
WilliamMok
Post by WilliamMok »
I am setting a whitelist with xxx.com to xxx2.com. When user sending email without "To" filed and only "CC" all the email address.
The Whitelist is not work on this situation and spam report 1.21 MISSING_HEADERS Missing To: header. Finally this mail is marked "Spam".
How can i reduce the score of the MISSING_HEADERS ? if there are any idea to bypass the checking with specific email domain?
Hope someone can help. Many thanks.
ovizii
Re: Whitelist is not work when missing "To" filed
Post by ovizii »
to adjust scores, simply create a myadjustedscores.cf file inside /etc/mail/spamassassin/ and add a line like:
score   MISSING_HEADERS                        X
X being the score you would like to assign to this rule.
:text-goodpost:
WilliamMok
ovizii wrote:to adjust scores, simply create a myadjustedscores.cf file inside /etc/mail/spamassassin/ and add a line like:
Thank ovizii!
i hv found a file located at /etc/MailScanner/spam.assassin.prefs.conf
When i add this code to the file.
The scoring is work. Hope can help someone in same problem.
The best place to put that is in the local.cf. That way it won't be overwritten during an upgrade, and you know that these entries will be loaded last.
