import latest build in efa in hyperv
bostjanc
Post by bostjanc »
Hi guys.
Trying to import VM for HYPERV but unfortunatelly not working.
We have 2012r2 hyperv.
Any manual steps needed to import it to hyperv?
Where to point (to which folder for vm?). We did selected every folder or subfolder and unable to import.
With best regards
bostjanc
Re: import latest build in efa in hyperv
Post by bostjanc »
I think this might be the solution (there is exp missing in the build):
https://blogs.technet.microsoft.com/rmi ... to-import/
But I have solved it by creating manually new VM and then selecting the hard disk file.
Anyway, maybe someone of you will find helpful the hyperlink I have pasted.
With best regards
