Disable link tracking for 1 domain
rvwaveren
Post by rvwaveren »
Hello everyone,
My company uses the EFA mailscanner for about 40 domains, one of these domains wants the link tracking disable. However - I haven't been able to find this anywhere, I found where I can disable it for ALL domains but not just for one.
Is this is even possible? If so can anyone point me in the right direction?
Thanks in advance,
Rory van Waveren.
Re: Disable link tracking for 1 domain
Link tracking? Do you mean the link fraud detection in MailScanner?
rvwaveren
Post by rvwaveren »
Hello shawniverson,
Yes, I meant link fraud detection. I'd like to disable this for one specific receiving domain. I hope this is possible!
I think it is....I am checking...
rvwaveren
Post by rvwaveren »
Hello shawniverson,
Have you found anything so far? I have been looking around myself but can't find any solutions. Thank you in advance.
Answer: yes
You can define a ruleset for this item...
# If a phishing fraud is detected, do you want to highlight the tag with
# a message stating that the link may be to a fraudulent web site.
# This can also be the filename of a ruleeset.
Highlight Phishing Fraud = yes
So you would create a file, such as /etc/MailScanner/phishingfraud.rules.conf
Highlight Phishing Fraud = /etc/MailScanner/phishingfraud.rules.conf
And create a tab delimited file with this:
FromOrTo: *       yes
