Is it possible to use EFA without SPAM-Filter?
Posted: 24 May 2016 13:30
by softfolio
I only want to use the virus-scanner. Where can the SPAM-filter be switched off?
Re: Is it possible to use EFA without SPAM-Filter?
Posted: 24 May 2016 14:12
by DaN
You could change the score to a realy high value viewtopic.php?t=910
Posted: 24 May 2016 14:37
You could disable spamassassin checks
Why would you want to do that?
