[SOLVED] Fixing missing SA rule descriptions
Posted: 22 May 2016 10:02
Sometimes, I look at the score of emails via mailwatch and the description is missing. So I created a file /etc/mail/spamassassin/my.own.descritions.cf and added the missing descriptions:
And sometimes that helps showing a description in mailwatch, sometimes not.
I now discovered that inside my DB called: mailscanner there is a table called: sa_rules containing rules and descriptions. If I add my rules which miss descriptions in here and add a description, it immediately shows in mailwatch too.
Can someone explain how this is all related and why my first method via .cf file didn't work?
And what happens when I go to mailwatch => Tools/Links => Update SpamAssassin Rule Descriptions ?
describe LOTS_OF_MONEY a lot of money mentioned
describe RCVD_IN_BRBL_LASTEXT listed in the Barracuda Reputation Block List (BRBL)
describe FSL_BULK_SIG Bulk signature with no Unsubscribe
describe KAM_VERY_BLACK_DBL Email that hits both URIBL Black and Spamhaus DBLI now discovered that inside my DB called: mailscanner there is a table called: sa_rules containing rules and descriptions. If I add my rules which miss descriptions in here and add a description, it immediately shows in mailwatch too.
