EFA autoupdate?
EFA autoupdate?
When I last checked the version of my EFA appliance, it was 3.0.0.9
When I looked this morning, it was 3.0.1.1 which is strange as I don't recall updating it. Is there now an autoupdate feature that I am unaware of? Or somehow it happened because I sleepwalked for the first time ever?
Just curious.
darky83
Site Admin
Re: EFA autoupdate?
Post by darky83 »
Already in there for a while, option 7 in the ssh menu 'Auto Update'.
(since version 3.0.0.1)
Re: EFA autoupdate?
Thanks darky83. I never noticed that before (shows you how much time I spend in the menu).
I guess I must have had it turned off in 3.0.0.7 and somehow it got turned back on in 3.0.0.9.
Thanks for the pointer! Mystery solved!
mayrmart
Re: EFA autoupdate?
Post by mayrmart »
Autoupdate ist not working for me (see attachment)
Any ideas ?
Martin
Re: EFA autoupdate?
So, your box is having trouble connecting to the internet, or it is having trouble with name resolution.
Open a terminal window to the efa box and send me the results of the following two commands:
1/ ping 8.8.8.8
2/ ping www.google.com
