Before I switched to using EFA I was using this script: https://github.com/extremeshok/clamav-unofficial-sigs/ with these instructions: https://github.com/extremeshok/clamav-u ... er/INSTALL to add additional signatures to clamdav but I am not sure if that will work with EFA or if it will somehow itnerfere seeing that the script is also adding mailpatrol signatures.
Any opinions from more advanced users?
Incorporate extra signatures into clamav
Re: Incorporate extra signatures into clamav
I can see that EFA uses the clamav-unofficial signatures package but that is from 2013 and missing a lot of the newer developments made in the project I listed above which has support for subscription keys for several providers apart from malwarepatrol and also incorporates maldetect signatures.
I would be great if this script could replace the current solution.
