3.0.1.1 :: Option 11 works, except anything gets enabled and not disabled
Option 11 works again except any changes made inside this menu gets enabled whatever you choose (Y or n)
Re: 3.0.1.1 :: Option 11 works, except anything gets enabled and not disabled
It's a security update feature, not a bug
Yeah, the logic is messed up somewhere.
Well, if .. then.. euh..?
Haha, thnx for the quick reply!
gdoornenbal
Yep! The fix works. Made a backup of the old /var/EFA/lib/EFA-Configure/func_apachesettings, and copied the new content over the old one. Happy!
+1gdoornenbal wrote:Yep! The fix works. Made a backup of the old /var/EFA/lib/EFA-Configure/func_apachesettings, and copied the new content over the old one. Happy!
The previous fix did not work for me on a subsequent site so I did the following:
edit /etc/httpd/conf.d/redirectssl.conf and changed
RewriteCond % HTTPS !=on
to
RewriteCond % HTTPS !=off
Then ran the following:
service iptables reload
service httpd reload
All is ok but if Option 11 is used again it reverts to https. So still needs fixing please.
to
Fix worked for me.
Thanks for the patch.
Still the same for me on another site. Could you look at a permanent fix for this please Shawn.
Working on itcolin wrote:Still the same for me on another site. Could you look at a permanent fix for this please Shawn.
