EFA 3.0.1.1 Security update released
Important news
Locked
We would also like to thank everyone for their support and contributions to this project. :clap:
The following issues have been fixed in 3.0.1.1:
Issue #201 Bug - Deprecated release-msg.cgi (deployed)
Issue #253 Bug - EFA-Backup ssl folder (deployed)
Issue #260 Bug - Header in Apache Settings wrong (deployed)
Issue #261 Bug - learn-msg.cgi wrong path for sa-learn (deployed)
Issue #273 Security - MailWatch Configuration Vulnerability
Issue #274 Bug - Broken menu options in 3.0.1.0
Please review the RELEASENOTES prior to updating for important information:
https://raw.githubusercontent.com/E-F-A ... LEASENOTES
3) If the update fails for any reason, immediately roll back to snapshot
sudo /usr/local/sbin/EFA-Update -check
continue the update process to 3.0.1.1
if present.
Locked
