After upgrade to 3.0.1.0 blank page on message view
mauropavanello
hi to all,
After upgrade efa to 3.0.1.0 when i go into message i don't see the message body, i see a blank page.
this is what i see.
Is this correct or this is a bug?
any help?
thanks
this is what i see.
any help?
thanks
- Cattura3.PNG (8.44 KiB) Viewed 37546 times
Re: After upgrade to 3.0.1.0 blank page on message view
Unable to reproduce
just this mail or all mails?
mauropavanello
some mail not all.
To recovery i have install from scratch and it's ok.
thanks for reply.
Bye
thanks for reply.
Bye
I can confirm, it is still in 3.0.1.1.
I found out, that in returns no 'body' element.
That is because in the mimeDecode Class the function _splitBodyHeader is searching for an empty line
For some reason there has been a change in the quarantine file format. I found older Messages shown correct with viewmail.php. This files has usual line-breaks. Now these files are one-liners with null byte (\x00) as delimiter. Perhaps another format (mbox).
Anyone knows where to change back?
Regards,
Thomas
theviewmail.php
$Mail_mimeDecode = new Mail_mimeDecode($file);That is because in the mimeDecode Class the function _splitBodyHeader is searching for an empty line
if (preg_match("/^(.*?)\r?\n\r?\n(.*)/s", $input, $match)) Anyone knows where to change back?
Regards,
Thomas
now it's got weird. I've changed nothing in the configuration, but got good and bad messages from the same sender and the same recipient once readable and one time not. It's an e-commerce-process generated message, so it has the same Body-Text and only little changes in a XML attachment.
The detail.php parses both Messages fine, displays all Header Information correctly. They differ only in Message-ID and Times.
At the end of this Page, where the "Quarentine" section is, they differ:
I have put a var_dump($Mail_mimeDecode) in the viewmail.php witch gives me, for the working
and the non-working
So it seems that something in the Mail-Scanner-Chain puts a bytecode in front of the message, which can not be parsed by Mail_mimeDecoder.
After a \0 comes the original Ascii, but with newlines replaced as N4
Anyone here that can give me a hint?
The working:
File Type Path
message message/rfc822 20160520/nonspam/4C50B121148.A09A9
message text/x-mail; charset=us-ascii 20160520/4C50B121148.A09A9/message
The non-working:
File Type Path
message message/rfc822 20160603/nonspam/520061201F6.A287E
520061201F6 application/octet-stream; charset=binary 20160603/520061201F6.A287E/520061201F6Code: Select all
Mail_mimeDecode::__set_state(array(
'_input' => 'X-Greylist: domain auto-whitelisted by SQLgrey-1.8.0
Received: from xxxxxxx.otherone (xxxxx [1.2.3.4])
Blah bla... all fineCode: Select all
'_input' => 'C_ 34670 793 2 0 34670 0T1464945569 489566Acreate_time=1464945570Alog_ident=520061201F6Arewrite_context=remoteSxxxx@xxx.A log_client_name=xxxA!log_client_address=1.2.3.4Alog_client_
.... and so on ... than
' . "\0" . 'N4X-Greylist: domain auto-whitelisted by SQLgrey-1.8.0N4X-Greylist: domain auto-white......
This sounds like a perl bug, perhaps from a recently updated perl module. I am going to investigate.
https://github.com/E-F-A/v3/issues/288
I don't think so. I guess it is earlier in the mail flow.
Since 30th of May (perhaps I did an update this day) Mails are stored in a different way in Quarantine. The old mailsource-text-only one still works and a new binary format which doesn't.
Also the filename differs. The old working was stored as 'message' file, f.e.
/var/spool/MailScanner/quarantine/20160524/3900D12114A.A5ECC/message
The non-working are stored as filename with the message-id, f.e.
/var/spool/MailScanner/quarantine/20160530/7B697120C11.AB25F/7B697120C11
What step or process is responsible for saving this Mails in Quarantine?
It looks like the new binary Mail format puts some more Information in the head of the File:
C_ 24379386 704 1 0 24379386 0T^Q1464783318 868859A^Vcreate_time=1464783318A^Ulog_ident=E884312018EA^Vrewrite_context=remoteS^Yxxxmailfrom@domainxxxA!log_client_name=xxxremotesmtpservernamexxxA log_client_address=xxxremoteipxxxA^Ulog_client_port=44054A3log_message_origin=xxxremotename[ip]xxxA^_log_helo_name=xxxremotenamexxxA^Wlog_protocol_name=ESMTPA^]client_name=xxxremotenamexxxA%reverse_client_name=xxxremotenamexxxA^\client_address=xxxremoteipxxxxA^Qclient_port=44054A^[helo_name=xxxremotenamexxxA^Sprotocol_name=ESMTPA^Uclient_address_type=2A+dsn_orig_rcpt=rfc822;xxxlocalmail@domainxxxO^Vxxxlocalmail@domainxxxR^Vxxxlocalmail@domainxxxM^@N4X-Greylist: domain auto-whitelisted by SQLgrey-1.8.0NDReceived: from .... Here comes the original Plaintext Mail, but with \0 as Line break.
And as subsequent fault Mime-Decode cannot parse this files, because it expected a Plaintext file with usual Line breaks.
Found it. It's in MailScanner.conf, this Setting
There was yes for me, default is no.# When you quarantine an entire message, do you want to store it as
# raw mail queue files (so you can easily send them onto users) or
# as human-readable files (header then body in 1 file)?
Perhaps e.f.a. should work with both values
