After update on 3.0.1.0 on Hyper-V there is nothing to see in Webbrowser
kastenkopf
Post by kastenkopf »
After update on 3.0.1.0 on Hyper-V there is nothing to see in the Webbrowser. No Login are possible. The Website are empty?
Testing with different Browser..always the same. No Login-Page will show :o :o
DaN
Re: After update on 3.0.1.0 on Hyper-V there is nothing to see in Webbrowser
Post by DaN »
What does /var/log/httpd/ssl_error_log or error_log, if you don't use tls (443), show?
Did you use LDAP auth login?
kastenkopf
this Error is in the Log-file:
[Wed May 04 11:32:14 2016] [warn] RSA server certificate CommonName (CN) `localhost.localdomain' does NOT match server name!?
This should be the error.? The Certificate looks like damage after the Update?
DaN
Post by DaN »
Something like
[xxx xxx xx xx:xx:xx xxxx] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[xxx xxx xx xx:xx:xx xxxx] [warn] RSA server certificate CommonName (CN) `localhost.localdomain' does NOT match server name!?
If yes, i don't think so. It's a [warn]ing, not more.
Just for a test... you could disable ssl/tls (11)).
mnewm3
Post by mnewm3 »
Getting "Page can't be displayed" after the update. Not using Hyper-V I've disabled SSL and no help. When I try to configure Apache in the EFA config console, when I enter 11, nothing happens.
darky83
Site Admin
Post by darky83 »
Login with ssh and use option 1 to go to the shell
then tail the apache config with:
sudo tail -f /var/log/httpd/*_log
And access the webpage, does it show any error messages?
mnewm3
Post by mnewm3 »
access is blocked to /var/log/httpd/ via SSH and that server is across town. I can see the directory but if I try to view it "No such file or directory"
mnewm3
Post by mnewm3 »
I can only access the root account local it is denied access via ssh.
ovizii
Post by ovizii »
well, after using your user to ssh, simply do a "su root" enter the root password and then follow the other instructions given earlier.
mnewm3
Post by mnewm3 »
I'm an idiot. I didn't have port 443 open prior to the update. All's well. Thx
